Transformer Searching
There are search functions in both the transformer gallery and Quick Add dialog.
To perform a search in the transformer gallery, simply enter the search terms and either press the key or click the search icon (the binoculars icon).
The transformer gallery search searches in both name and description. Therefore a search term may be the exact name of a transformer, or it may be a general keyword referring to functionality in general:
Search terms can either be full or partial words, and may consist of a number of keywords, including quote marks to enclose a single search reference.
Quick Add search-terms can also be full or partial words:
By default, Quick Add does not look in transformer descriptions, so the search term must be the actual name of a transformer.
However, Quick Add will search in the transformer descriptions if you press the <TAB> key.
Quick Add results include aliases - for example transformers that have an alternative name or which have been renamed - and also include transformers found in the FME Hub.
Firefighter Mapp says...
in case you weren't aware, the FME Store (store.safe.com) is a facility for sharing (and selling) FME functionality such as custom transformers and formats:
Transformers from the store are flagged in Quick Add with a small, downwards-pointing arrow, to denote that they will be downloaded if selected.
CamelCase
Quick Add also allows the use of CamelCase initials as a shortcut. CamelCase is where a single keyword is made up of several conjoined words, each of which retains an upper case initial; for example AttributeFileWriter (AFW) or ShortestPathFinder (SPF).
Miss Vector says...
Try these questions to see if you can search for transformers.
Which of the following is NOT a category of transformers?
1. Database
2. Formats
3. Linear Referencing
4. Surfaces
Here are four transformers and four categories. Match the transformer to the correct category.
ScenarioTool
ChopperInfrastructure
TerminatorCalculators
MatcherManipulators
DateFormatterFilters
results matching ""
    No results matching ""
