The transformer gallery is the obvious place to start looking for transformers. There are a number of ways in which transformers here can be located.
Transformer Categories
Transformer categories are a good starting point from which to explore the transformer list. Transformers are grouped in categories to help find a transformer relevant to the problem at hand.
TIP
Notice that each category lists the number of transformers that it contains!
Important categories include:
  • Calculators: Calculate a value and supply it as a new attribute
  • Database: Interact with external databases
  • Filters: Split and re-route data
  • Geometric Operators: Process feature geometry
  • Infrastructure: Structural transformation and scripting with Tcl/Python
  • Strings: Create, modify and delete string (character) attributes
  • Workflow: Run workspaces either locally or on an FME Server
Simply click on the expand button to show all transformers within a particular category.
Transformer Help
The FME Workbench Help tool displays information about transformers. Simply click on a transformer and press the F1 key to open the help dialog.
This tool is linked to FME Workbench so that a transformer selected (in the gallery or on the canvas) triggers content to display in the Help tool.
.1 UPDATE
In FME2016.1 the help window was altered to not update automatically when a new object is clicked on.
But in 2016.1.1 this behavior was returned, along with the embedded help window!
TIP
Another useful - and printable - piece of documentation is the FME Transformer Reference Guide.
results matching ""
    No results matching ""
